Big Booty Judy under new ownership, Advise on possible plastic surgury ?
man i hate double "b"s but here you go.
Tried to address the browbar, and the top back of the cage....
maybe just redo the brow, and add your b pillar and be done.
So you can see side by said all the subtle
[attachment deleted by admin]
I can't come up with much on the ass of this thing.
This is it so far. Similar to Wyatt's, and the brow bar is hard to show since I tipped the A pillar way back.
MUCHADO said:
put the parts on a new chassis if you're just gonna cut it all up!
Too much work to rewire/plumb it. Chopping the top off and I'd assume non permanent skids would be what Travis is after???
beltline up, except i like the rear of BBJ, I even like the current cage. Just ditch the stinger and add door bars, and rock out.
Ben did a damn good job on that thing. Next mod I'd do it ditch the doubler for an atlas.
I like this. The A-pillar is just soooo far in front of the seats. Makes for a huge passenger compartment and small hood. Angle back the A-pillar and add some door bars and I think it would help alot.
pretty much what I was trying to say. If you do anything at all, start with door bar and rear sweep to a bedside. Any after that, chop from the B forward like Heath and lay it back some.
I like the more vertical windshield areas as long as they are short. Looks way more racey to me than huge windows swept back. but its all personal preference.
:woody: :woody: :woody:
I really just want to change from the b pillar forward, change stinger, and add door bars, along with changing up sides. first big upgrade its getting besides seats are ori's. I need to go get heathers, he will never use them
Wb is 112" belly is like 24" nope not going to lower it or do anything with suspensionm you sit next to the t case, thats why its so wide. Its pretty darn stable as is even with airs.
I like the double b pillars at the same angle but it would be alot of work cutting the existing b pillar out , thats why I'm thinking adding one at a angle like this buggy ( which is one of beyers buddys I think )
