Your quite the creative fella there Bill![]()
on a budget here Crash
Drive toe and coast heel--I would work on your pinion depth more. Also the drive side is pretty narrow from the pics...
hey Crash..you know this is a front so it is running on the weak side right
it was the carrier that didn't have enough pre-load...fixed that...checked...pushed the pinion in .010...it bound...took out .005 and still tight...took out .002 more and it is at .004 backlash and the pattern is about the same
from what I have read these gears are rejects from Yukon...so I will take what I got....
and my back is really sore now
Have you done this before?...You shouldn't be doing anything with preload until it has a good pattern......You can get step by step directions from Randys that are prety good...:awesomework:
this is how I mark them to shave...I think its pretty cool
I did a writeup on that process about ten yeras ago.....I wonder if I can find it?......
Seriosely though. Your writeup makes it look like you've never done this before. May want to go back and edit in some better information....
