toyotalandman
love the way the fith study turn out how thick is the steal you used for it
I did it since I have the new 40* LongfeildsModified the felt ring for max steering....
haha why did you do that?
couldn't you have ground down the knuckle ball gussets or what ever seams to be hitting the felt ring..
hope you don't mind a leaky axle
The knuckle ball gussets would have to be ground down quite a bit to make the rings not hit them. Also the felt ring itself in the upper middle is now what makes contact on the housing. This is even after the lip was removed in those areas.
Marlin HD seals are in the axle so leaking should not be a issue. Or so I hope.
40* huh,what are the original 30 spliners:eeek:
i didn't hack the ring at all...
This is a tricky Q.also does the turbo booster have more brake assist then say a non turbo booster?:eeek:
This is a tricky Q.
Booster size and MC size do not make better braking on a stock rig. Bigger is not better in stock cases. Caliper sizes, drum and caliper-caliper and caliper systems, ext all will effect how brakes work.....
A turbo booster is a dual diaphragm booster like on newer rigs due to there brake size upgrades over the years. Turbo trucks-runners were the pre-runners to the V-6 rigs.
It makes a difference, but only when you start to mix and match different sizes and styles of brake components.so i guess your saying it doesn't make a differance then? so why change from a non turbo booster to a turbo one:eeek:.... not that it matters but i am running chev 1/2 calipers in the rear, stock 85 brakes up front, a 1in master cyl, and a summit/willwood perportioning vavle, and 37-39in tires, would a turbo booster help me stop quicker, note my truck stops on a dime as it is, rear disk was one of the best mods i ever put on my truck![]()
Read this thread..... a few explain it much better than I.
http://pirate4x4.com/forum/showthread.php?t=763888&highlight=brakes
After reading this http://www.pirate4x4.com/forum/showthread.php?t=721603&highlight=anti+wrap+bar (post #10) It seemed to make sense to me.i was told/read that basiclly you want the traction bar to mount in line with the front spring mounts on the rear springs, why would longer be better?
