Bolt on Stickers
:haha: Will it do wheelies?
do you love cawk :fawkdancesmiley:
wiring done and water proofed as best as I can get it.
turn signals re-wired/restored
snatched up a 1952 M100 trailer for a few bucks, had to have it. It will go to this jeep as a camping/overland exp trailer.... more to come.
How do you like the Victory? I've looked at them but never rode one, couldn't make the leap from the HD. :D
Looking pretty good, have you done your T-case yet?
thanks bro,
tcase is next on the list, well the cross members. I have everything ready, just gotta get some polly bushings and see if I am going to be able to clock it flat without cutting too much out of the floor.
No, he is looking for adhesive remover in a can so he can take off all the stickers...:haha:
I have the rear antirock sway bar on the way... hope those foos send mo stick'uhs, gotta decide what I am gonnna do with shock mounts, and finish brake lines and the rear is done. :flipoff:
here's a puppy who loves pork rinds
I just finished a CJ tailgate swap on my TJ.
I made a 3/16" strap all the way across the flat spot on top of the tailgate to get toyota pickup latches to set out flush with my corner guards. I threaded the inner hole for the latch and used a cut off bolt into the strap. The outer hole is drilled through the strap and through the tailgate lip with a nut on back. Make a couple of ears for the latches to hook onto and it works pretty good. I just made 1/8" backing plates with nuts tacked onto them for the stock CJ hinges. I was able to fish those up into the factory cut out body holes under there.
FWIW if you decide to look into this I was able to find the latches on some low rider parts website for $1.16 each. So buying new is way cheaper than looking for used ones.
0 Words
