smbroady82 said:the tractor tires not cutting it anymore?
kmcminn said:Maybe after the boggers he can do your 42's?
Rockwells607 said:I built a set and asked around before I did em, most common setup I found and used was 3" carriage bolts 1/2" diameter , put a 5/8 flat washer on the bolt head and pushed bolt through from the inside . Then put 1/2" flat washer on the outside and 3 hex nuts and weld the top nut to the bolt . I made a drill just like a snowmobile track used for ice picks. It takes a core out so the bolt can go through
Bronco72 said:Bolted 44" boggers on that low pinon CHEVY 60? Ill get started on you a hp FORD axle... lol
poolman said:If I do it I'll probably only do the rear tires
Edit, the R&P would be the only concern, but shouldn't be any worse than a 43 stickie?????
