Boonie's Build of Debauchery
So I spooled the new rope on and the battery is leaking... :mad: Not that i expected anything less, i don't know much about the battery in it, but it's def. not cut out for the load, or my wires/grounds are bad :eeek:. The winch had all good clean connections and i put new end terminals on the battery side of things.
Any suggestions for a good battery? :corn:
Optima Yellow top and a higher output alternator, expensive but way worth it
$20 at the local yard. Look for the largest and newest one they have.
Or go get a $100 plus battery and hope to never damage it.
I have an optima blue top (gray bottom, starting only battery apparently :redneck:) that I used to run in my S-10 w/ a high output alternator and this exact winch and never had a problem, but im just concern with using a lower output alternator on this system that it will be harder on the battery? I dont know...
I guess i wish i knew WHY this was happening, it happened before when i had a power inverter hooked up to the cig lighter for a brief time (hour at most) with the truck turned off and again when running.
I'm am the farthest from an electrical guru there is. I could ruin a flashlight if given the chance. :redneck:
EDIT:
Maybe the alternator is overcharging....? :eeek:
It's easy to have both the alternator and battery tested. If you don't have the guage, NAPA will. I like yellow tops, have one in my jeep. I've done a fair amount of winching and it's worked fine with the stock alternator. You pay for it though. My wheeler has a regular battery and it's done fine winching as well, I just don't think it will last as long. Buy what you can afford.
I checked the alternator last night and it's charging fine. Granted it's not a high output alternator, it was still charging. I'm thinking the battery has a dead cell, it died a couple times over winter and is ran only on occasion, so it's had a hard last year. :redneck:
So, I've been a busy little beaver for one day. Went and cleaned the intake and throttle body, it now runs better but still has a hesitation, thinking it's the TPS at this point, but have yet to test it.
So while waiting for gaskets to show up for that portion of my weekend i made these...
Which turned into these:
Looking up at the bottom.
I have yet to drill them out to the proper hole diameter i want to run, i need to drill them out slightly if i use the metal sleeve portion of the RUF's I have. Which is fine, everything is lined up now and ready to go, I can have this installed on the truck and still have my IFS pimping big! :redneck:
Front View:
I still have to do some grinding and put a winch rope plate "guard" along the back to protect the rope from getting gouged on a sharp corner of the body that sticks out.
So, I mounted the winch/spring mount to the truck. Was wokring to get the winch bolted on and broke a bolt, and the drill was nowhere to be found, so that slowed progress. But here are some pics of the mount in relation to the vehicle:
Sometimes a few different angles are helpful to see different things...
Side View:
Front View:
Installed a new style exhaust header on my 2.7L engine, runs way quieter, the old manifold had two large cracks, one of which almost went completely around the manifold! :eek:
Anyways,
Started rebuild one of two E-Lockers this past weekend. And to make my life easier I whipped up a quick and dirty 3rd member stand. So far it has made the job 100 times easier! :welder::saw:
It's ugly, but it was meant for one thing. Note the use of a spider gear from a SAS Chevy Luv project I had years ago. Bling Factor!
The diff looked as though it was living in a peet bog for the past 20 years.
I completely tore down the 3rd to nothing. Here it is on the stand in a tub of it's own filth while cleaning it.
I also tore down and cleaned the locker itself as the bolts holding the case together were only finger tight.......:eek:
I'm seeing a lot of Toyota and not much debauchery.......:D
I like the winch mount....when can I get one? :cheer:
Ha ha! Sorry, there was no debauchery because none of my friends came over, I was actually able to get work done! :fawkdancesmiley::haha:
The winch mount..............no'fo'sale! Isaygoodday! :redneck:
What I got done this weekend:
-Assembled wheels and tires
-Regeared E-Locker diff
-Installed new exhaust from header back with new O2 sensors
I put some BB's in each tire as per my usual balancing act. This time it took a bit longer though...freebie with the BB's! :awesomework:
Almost installed:
Obligatory gear pattern shot for critiquing.
