Bounce
Lower your antisquat.
If you want to spend the time getting it right before building any new mounts,
Put link locations in the 4 link calculator,
And minimize your antisquat increase thru suspension droop.
Using shock valving to control wheel hop is a band aid, it can be done but doesn't fix the source of the problem.
Gadametz said:
Theres not much clearance to lower ride height. I could definitely use weaker springs though.
Then you'll have to build a subframe to lower your lower link mounting points.
That's why 99% of the tube buggies you see have a big ol belly frame hanging down under the driver compartment.
Either that, or like most of the rock bouncer type chassis, the engine/trans/tcase is mounted high and forward (driver sits low behind tcase).
What is antisquat? Thanks for the help
