Brainwashed
Update. I have been fine tuning it mainly at the shock level from rates to shock travel. I found the combination that I lied was a medium rate for the front and a stuff for the rear with my 4" shocks limited at 1/4" of there travel.
So last night I finally decided to do something I have been contiplating for some time--I really wanted to lighten up the chassis but also run a very narrow chassis (and still run a 4 linked rig). Well after some drawings and work here is what I came up with.
Old vs. new
Got all new links made up and reworked the shocks how I wanted them. The front shocks did not change but the rear had more slant so I upped the rates just a bit and that should work pretty nice hopefully. I also redid the wiring and was able to squish the goods down on top of belly like I was hoping too..
I went with 3" belly--there aint crap for any wieght on the chassis now.
Underside shot...
Got the body back on and was only able to test it out on a new rock pile at my buddies--hope to do some testing on my familure places here this week to final tune it..
Hoping my brother in law wants it--you want one eric?
Yes please on a chassis:awesomework: I am finding the limits to the stock berg chassis. RIght now its limiting my flex.
If you are making chassis let me know how much you want for one. I think I will be ditching the body very shortly. I keep getting it stuck on things.
And of course Don has first dibs
Eric do you have a tap plastics down by you?
no tap, we have a kel tech plastics which I think is about the same but they dont sell small pieces that I know of. Best bet is their scrap bin which is only an iffy chance at best.
What do you need? Or what am I looking for?
Looking for 3/8" and 5/16" sheets (and by that max size of 12"x12")
My bad--delrin :awesomework: Will be for skids and link material...
I will have to check, the problem is I dont really know what delrin looks like for sure and their scrap bin is not labeled.
I will figure it out.
I take it you take trades for a chassis? is that what I am looking at?
Exactly :awesomework:
No delrin at Keltech, they dont work with the stuff :booo:
would you be interusted in a trade for cash? I can write on the cash that it is for delrin?
Ok so I have been thinking hard and finally did it--built a new upper link mount for the rear.. It was a tricky lil bugger and is made from 3 pieces of material. I made the first one to get my measurements perfect on the final one.
And here it is mounted to the axle.
So now I have 1.5" of seperation at the diff. Also the key to the mount was getting the perfect angle on it since I am running the rod ends at that angle.
I had to give the upper links a tad of an "S" shape to work around the shock mounts and diff. But now the links don't hit anything.
But I think it turned out pretty good..
