onetoncrawler
Manual brakes, 7/8 master cylinders - 1 for front and 1 for rear - stock chevy 60 calipers on front - 3/4 calipers on rear....... after bleeding brakes i have no pedal on either one MC for the initial push, after pumping about twice they stop fine and seem to hold OK... a friend suggested putting residual valves in line so i have some on order , any other suggestions?
Full Hyro Steering - 2X8 SE ram, 4 port orbital, stock 5.3 pump, w/ a cooler on the return line ....... have not properly bled the system but after cycling the steering left to right multiple times it seems that the pump is not hooked up at all... i did try reversing the pump and return lines and it made it harder to steer and i got kickback. I have it plumbed per PSC's diagram. is it as simple as bleeding the air out or do i have other issues? I have noticed that when i remove the pwr steering pump cap i can hear air escaping almost like there was a vacuum on it. should i leave the cap off while bleeding?
Thanks!
Thanks!
