Brake Issues !
mine did the same thing i had to upgrade to a 1" bore master cyl and it does ok not still not the best, i almost wish i would have went to 1 1/8 for the front
i may have to try that, im just not sold on the fact that 1/8 difference in bore is going to make or break the system. the rear calipers are that much smaller than the front and they work like a champ. the front has nothing :dunno:
i guess i will play with them a lil longer, let them self bleed over night and if that doesnt help order a 1 1/8 unit
thanks!
just run the math on the size differences you will be susprised at the difference
well after letting the brakes sit over night they got a little pedal , after riding for an hour or so they worked just as good as the rear :eat:
they stop good but i can tell they have air in them, i guess i will try to bleed them again and hope i dont loose brakes again
I had same problems a couple years ago, I had a bad caliper that didn't leak, just didn't work right
