1TONZR2
Big mudda fugga!
well, its pretty official, I have been bitten. you fawkers and your buggies dont help my wallet at all.
After last weekend at Windrock, nearly rolling down the mountain a couple of times, I decided that I need to do something that will protect me a little more than what a cab will....especially if I keep wheeling the places that I do. I have tossed around the idea of just making my truck into a truggy, cutting the back off, adding a **** pile of tube and a cage on the inside of the cab, since I really dont like the looks of exo's all around the front part of the cab. then I start thinking, if I am going to throw that much tube at my truck, why not throw it into a buggy that I will be able to beat on SAFELY. Luckily, the wife does see my point on this.....
I have been searching around for some bare bones chassis's and came across the 4Play by Bent Fab. It is designed as a 4 seater, but I would make it an "extended cab" 2 seater. I have been emailing Tim back and forth about what can be done with this chassis and I really like his options so far. we talked about moving the seat mounts back some since I am FAR from average height, then using the space that would have been for the back seat as storage for a cooler/tools/spare crap. Here is the thread about his 4Play chassis---http://pirate4x4.com/forum/showthread.php?t=664394
To me, the price for this chassis is pretty damn reasonable. I would love to spend less on a chassis, but I dunno if it will happen. I have already started a list of parts that I would need to make this chassis into a full blown badass buggy...IMO I might need some advice on what kind of parts you guys have had luck with and what is junk. I am sure I will be getting some parts from Kelly, atleast I hope so.
here is a list of what I need so far:
Chassis
new engine harness
custom fuel cell
DPI 14†struts
Atlas 3.8
drive shafts
steering wheel
non adjustable column kit
WW-340-1290 single MC, high volume, .75†bore
skid material
skins and hood material
brake lines--nylon kit from Speedway
fuel lines
5 point harness
cutting brakes?
new hydro hoses (local)
here is what I have:
5.3L V8
4L60E
42x14x17 IROKs on TRs
Dana 60 front chromo 35 spline inner/outer
Dana 60 rear (getting a 70 soon I hope) w/ disc brakes
PRP seats
B&M pro stick shifter
RCI fuel cell
Warn 9.5ti
Howe dual pass radiator w/ taurus fan
Full hydro steering kit
16" SAW coilovers
I am thinking about using 7075 for my lowers and 1.5" DOM for the uppers. what about link ends? I am currently using 3/4x3/4 in the front 3/4x5/8 in the rear. should I upgrade to a rebuildable joint? will one of those rebuildable joints fit in the link mounts already on the axle?
Thanks
Brian
Chassis
new engine harness
custom fuel cell
DPI 14†struts
Atlas 3.8
drive shafts
steering wheel
skid material
fuel lines
5 point harness
cutting brakes?
5.3L V8
4L60E
PRP seats
RCI fuel cell
Warn 9.5ti
16" SAW coilovers
Thanks
Brian
