Buggy build "Indecision"
Buggy is looking GREAT! Here is a Picture of a cooler I put in my rig, a simple golf cart cooler. Weld a tube in and clamp her down. I put a strap over it for the upside down stuff but it worked out great so far? Just a suggestion, Keep up the NICE work.
I definitely like that cooler set up. I think I would want it a little lower, but definitely cool. What do you mean golf cart cooler?
Or a good roll and bout knock yourself out on it. I got stitches in my head from a soft cooler coming loose during a roll. of course it did have beers in it :drinkers:
pholmann said:
Laugh if you want but cupholders are a must!!
Yep, got to have somewhere to put the beers. I was looking at the plastic and stainless marine cup holders they have at Academy a few days ago. Those would work good if you have enough room under your console to recess them.
Cooler is a golf cart steering shaft mount. Holds 12 pack, with a small ratchet strap over it you would have to do alot of rolling to loose it? I have yet to hit my head on it, NOT saying you couldnt? Drill small hole in bottom corner so it doesnt hold water to dump. SO FAR SO GOOD?? Just an idea that has worked for me, thought someone else could put to use.
i wasn't knocking your idea. its actually a pretty good idea. I just see how close it is and if you had a bad roll might could make contact with it
O no problem, I took no offense. I have hit my head on my cage and not the cooler YET? It seems to sit far enough back that it hasnt been a problem? I was affraid of the ice water bath when I first installed it, That hasnt been an issue yet either? That is why I posted the idea. Some of the little items you try to incorporate in a build can be the ones that drive you crazy....
Re: Re: Buggy build "Indecision"
rednecklights said:
Magnetic coozie ftw
I've got a YETI coozie and I wanna get an adhesive magnet to put on the bottom.
Sent from my SM-G900V using Tapatalk
