Building my junk.
Hey pat i want that intake that you offered up, when could i pick it up? You going to the swap meet ?
I know you have alot of b2 parts do you by chances have all the brackets to run a ac pump on the 2.8?
Btw the bumper looks awesome :awesomework:
Redid my remote oil filter lines with summit racing twist tight hose and AN fittings. No more barbed nipples and hose clamps. :headbang:
Finally got the fox body mustang motor mounts put in.
I had to trim a little off of the stud to get them in between the motor and crossmember.
The trans mount was trashed.
So I ordered up a poly mount for a 5.0 fox mustang. They are the same height as the 1986 and newer RBV trans mounts. (83-85 are shorter, and don't interchange.)
I had to swap to a newer crossmember to use it, so I got one from a 91 exploder. I found that at least on the energy suspension mount.. the spacing for the bolts is different from the RBV mount studs... So I had to make some new slots in the crossmember, then welded up the factory holes.
Drill a couple holes in the passenger side of the frame for the new cross member studs, and we are in business.
Been a while since I worked on my junk. Did some little **** like replaceing all the lights but the head lamps with LEDs...
Today I did a Ford 3G alternator conversion. The 3G is an internally regulated alternator that is basically one wire, and in this version, puts out 130 amps. I stole mine from a Taurus. Google it if you want more info. Basically, they kick ass. It kept putting out 14.5V even with all my accessories and lights/fans on. A superior upgrade from the externally regulated 60A 1G my rig came with.
Nice.
I was thinking about you today (no homo) there was a guy beating the **** out of a stock BII at walker. He trashed his passenger side glass. :booo:
Probably not. I have to do ball joints/seals/locker/gears in the front axle, and swap the rear axle to one with 4.56s, plus put my locker in that... not gonna be up and running for a month or so... plus I still need to have my shoulder heal before all that... :rolleyes:
35s fit great. Thinking about stretching the wheelbase a couple of inches to the rear to get the rear tires more centered. Other than that, it has the extra width I needed.
