Bump Stops???
I hear Timbrens are good too.
Walked around pull-a-part for a while... Found some Pathy bumps...:fawkdancesmiley:
Was thinking threw how I was going to mount them, then it clicked... Use the stock "L" bracket off of a Chevy frame that's behind the rear shackle mount... Any one that's done a shackle flip on a Chevy knows what bracket I'm talking about...
Here's the bracket...
Welded a bolt in the the hole for a stud...
They will bolt to the frame using the top holes...
After I see if they work, They will get mounted permanant... If they don't work, then back to the drawing board...
i could have saved you a trip, i have 2 sets of those.. :D
Oh well, thanks anyways...
Bumps are only $2.50 a piece out there and I wanted to look at a bunch of types...
Picked up a set from a Honda Passport that look pretty solid...
Still need to figure out bumps for the front...
