Caddi on the surgury table
The delphi computer is nice and small though. The factory ecu has a diagnostic port. Look at aeroforcetech gauge. We got one for Levi. Plugs into the obd port. Its way cool!
Caddishack18 said:
Speedway has huggers for $279 ceramic coated.
Thoso header are definately going to work. Look good coated too! You need to change your motor mounts around though. Its a bad thing to have your bushings out by the frame. If you start pounding on it you will break or pull the bolts out of the block. Been there,
It will be fine once a hoop is added between them to attach both sides together.
