Chev trouble codes
I had to reset the timing after replacing the intake gaskets, Yes I did it with a light and brown wire under dash disconnected.
EGR is new and is installed correctly.
Reluctor phasing? I don't know what that is and how to check it.
Coil could be swapped with the 4.3, may try that today.
Codes-- yes most are from unplugging or stuff, I will clear them today to see if I get 15 and 54 again
54 is also unacounted for as far as I know.
Fuel filter is new, less than 100 miles on it.
I don't have a way to check fuel pressure right now.
Thanks for the ideas
Stoopid fuel pump:mad: Stoopid me:looser: Going wheelin soon.
Thanks to the White Knuckle 4x4club that got this fixed for me during a time where I need to be with my wife and when my broken truck is the last thing on my mind. I didn't ask they just did it.
Thanks guys.
Also thanks everyone that helped out in this thread. I learned alot and a couple of you were leaning toward the fuel pump. I just don't have the stuff to check fuel pressure.
