crash2
-Oh no I picked a side-
Ok the driver side frame rail was a bit of work since I made the choice of cutting the plating on the frame way back to the steering box.. But I got the brackets/plates rough cut off....
was the oil cooler something stock? Just curious as to why it was put on then...
Yes sir--OEM setup...
That oil cooler was there (from the factory) for a reason. GM V8s, when transplanted into small radiator vehicles, are not uncommon to have overheating issues during extended operation (hillclimbs, racing, coming off freeway driving, etc). An oil-cooler helps to keep things in line.
IF it were my rig, I'd leave the cooler installed, but simply put a bypass hose between the two lines. This allows it to be easily utilized at a later date, if needed.
The cooler can also be swung 180*, if you want to install the cooler in the rear of the vehicle.
Mike I found the a/c delete pulley but i was wondering if it were possible to just make that a compressor to run air by tapping those holes?
