CL of the day
L33 info
L33[edit]
The Vortec 5300 L33 (VIN code "B") is an aluminum block version of the LM7, and was referred to as the Vortec 5300 HO in marketing materials. How ever it should be noted that the L33 uses a flat top piston from the 4.8L instead of the standard dish piston found in the LM7. It also uses 799 cylinder heads, which are identical to the 243 casting found on the LS6 and LS2 with the exception to the Corvette spec valve springs, and hollow stem exhaust valves on the 2002-2004 LS6. This combination increased the compression from 9.5:1 to 10.0:1. Also the L33 had a specific camshaft not shared with any other engine, with lobe lift of 7.2 mm, 193 degrees of intake and exhaust duration, and a 116 degree lobe separation angle. As a result power increased by 15 hp (11 kW), to 310 hp (230 kW) and 335 lb·ft (441 N·m). It was only available on extended cab 4WD pickup trucks. Only 25% of trucks made in 2005 had the L33 engine.
L33 applications:
2005–2007 Chevrolet Silverado 1500 4WD
2005–2007 GMC Sierra 1500 4WD
__________________________________________________________________________________________
LQ9 Vortec Max info
LQ9[edit]
The Vortec HO 6000 or VortecMAX is a special high-output version of the Vortec 6000 V8 truck engine originally designed for Cadillac. This engine was introduced in other truck lines as VortecMAX for 2006. It features high-compression (10:1) flat-top pistons for an extra 10 hp (7 kW) and 10 lb·ft (14 N·m), bringing output to 345 hp (257 kW) and 380 lb·ft (515 N·m). LQ9s are built only in Romulus, Michigan.
LQ9 (VIN N) Applications:
2002–2006 Cadillac Escalade
2002–2006 Cadillac Escalade EXT
2003–2006 Cadillac Escalade ESV
2003–2007 Chevrolet Silverado SS
2004–2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only [Badging on truck](B4V)
2005-2006 GMC Sierra Denali pickup and Yukon Denali
2006–2007 Classic Chevrolet Silverado and GMC Sierra VortecMAX Option
It was for a reference as to what it came in from the factory. L33 is not considered Vortec Max, although it is a higher output version of the 5.3L
I had an incorrect reference on the trailblazer SS, it has the LS2 6.0L in it. There is also a version of the 6.0L called the L76 that was labeled as Vortec Max. Last year of Vortec Max availability was 2009
I have a 2005 1500 with the L33. For being a halfton it pulls like a sumbitch. Dad has a 6.0 and I've been wanting to pull the jeep with it to see if theres any difference other than mine will probably get better mileage towing and way better mileage empty. I had a tuner on it and ran even better but I sold it to my brother.
Re: Re: Re: CL of the day
rpf500 said:
My piece of **** is in pieces but I can fix it in a week EASY. Trade me for a running race car though. WTF is wrong with people? Geeez
http://evansville.craigslist.org/cto/4796769814.html
Come on now you know you want that pos.....
Reads to me like I got no money or ni want to fix this truck and want to go fast on a dirt track because my Mud Life cover truck build didn't work out.
rpf500 said:
Built not bought....
https://evansville.craigslist.org/cto/4803677740.html
Looks like, bolted on, not built.
Sent from my iPad using Tapatalk
