TacomaJD
I LIKE CHEAP STUFF.....
Re: Re: Re: coilover help
That's another good point of having the lower spring 2" longer than shock travel like mentioned above the slider should never come off the shock body with that setup.
Maybe I'll be able to get it right by adjusting preload and not have to swap springs.
RustyC said:Josh you can also turn the dual rate slider over too. I think they are actually correct with the short side up anyway.
Just make sure that at full droop the slider does not come off the shock body.
Should ride a lot softer now too.
