Coilover mounted on steering Arm Question
wngrog said:
I have seen this done lots of time, but there is already enough problems with knuckles to add all the stress from jumping and rock bouncing to it.
I would look at this hard and try to get the shock on the tube. You hang with this crowd and your hood is going to get bashed anyway, you need to buck up for a plastic one and cut it out for the coilovers.....
He drives like an old woman there won't be any rock bouncing from Daniel. I compare his driving style to yours, like to crawl around.
blacksheep10 said:
so by transferrence, nolan drives like an old woman laughing
I knew someone would make it sound like that. I just meant that Nolen does't Rock Bounce.
Im not Hating ;D
I think if Blackcock and I are talking about the same thing you shouldn't hit the frame at full droop. The bracket welds to the axle tube and then goes up and over the steering arm. The coil eye would be in just about the same place you have it or wherever you might want it and you have none of the twist associated with the steering arm. This is all just in theory of course cause I'm a rigless nonwheeling hater!
you aren't a hater, you're a lover.
0 Words
