TacomaJD said:That sounds pretty close to what I guessed. What motor is in it? Mine were 14" coilovers on the yota, 16" lower / 14" upper, started with 100/200, way too light. Ended up with 150/200 and it was still soft, but if I went with stiffer spring, it would have been sitting up too high in front. I had fixed bumps in front and it didn't take much to hit em hard if I slammed the front end down or hit a big bump fast. I adjusted the dual rate stop ring to where it would catch the heavy spring earlier on uptravel and it helped alot and still rode smooth on the top spring. You just have to play around with it once you get close with the springs.
rpf500 said:If you can get your hands on a 18" x 200 lower I'd try that on the rear and see if that gives you more stability. I recently changed from a 200 to a 150 and it had a noticeable difference in body roll, meaning it had a lot more.
Where did you set dual rate slider ring? A lot of guys go for 1". If you are above that, try moving it down so your dual rate starts sooner to see if stability increases.
zayne2427 said:George let me borrow some springs
Fronts are 16"-150 over 18"200
Rears are. 16"-100 over 18" 150
Got them on yesterday and went and rode some private land.
Zero preload and ride height was still a little taller than planned but manageable
8.5" front shaft showing
7 3/4" rear shaft showing
22 3/4" belly height
With any preload on the uppers it would put me taller than I need to be
. Ride was 100% smoother than the heavy springs that were on it but the body roll is definitely something to get used to even with a rear sway bar. Need to recheck my nitrogen pressures and see if i can adjust height there some. Will try and get some better measurement this afternoon and get some opinions on getting this big ole girl dialed in a little better
they are still on there at this time, but are completely collapsed even at full droop with the current springs installed.TRD said:That's good you're not using tender coils any more. I've actually seen the tender coils make the measurements difficult.
Tender coils are not desireable because they don't have enough force to push the axle down when drooping, and they don't provide significant traction when articulated.
