Coleworx Terminator
Turning a dia. on the hex for the ram mount to lock into is a pretty good idea. I've always loved how the Coleworx buggies have a low front shock mount position..this rig looks like you could ride all day and actually see where you're going.
Also kinda looks like a BBC under the hood ?
More specs
• 408 LS, Holley EFI amd Speedwire systems relay panel
• PTC 400
• SCS CASE with High Angle Driveshafts
• 14 bolt front, RCV shafts (47/40 spline), aluminum hubs and Wilwood brakes, Nitro 4.56 gears and Spool
• 14 bolt rear with Ouverson shafts, aluminum hubs and Wilwood brakesNitro 4.56 gears and Spool
• Trailready Wheels with Mickey Thompson stickies, Coleworx rings
• Fox DSC remote reservoir shocks
• PRP seats
onetoncrawler said:
Thanks for the compliments guys.
Sent from my SM-G973U using Tapatalk
Sharp looking rig and glad to see it finished up! Going to make its debut at Hale next weekend???
Thanks! Man i hope to make Hale Saturday. Just gotta get it tuned, hopefully that can take place this week
Absolutely badass.
The pictures had all my french friends in awe, and I feel like a lucky SOB to be able to drool on it IRL at some point :smoke:
Daniel and Brian knocked it out of the park 8)
FANTASTIC job Brian and Daniel. I know how particular you both are on details so that leads me to believe that until you you have been up close to this machine, you are only seeing the eye candy part of it. Can't wait to wheel with you Daniel. :dblthumb:
ADMINISTRATOR
kmcminn said:
More specs
• PTC 400
• PRP seats
Which holley efi is this?
Folks that don't know Brian don't understand the builds. It's just his style, no it's not a modern race rig nor was it intended to be. Brian's builds have always been 4x4 show cars that can absolutely be beat to death. Daniel knows his stuff as well, it's always about doing something nobody else does on these rigs, that's the whole point. Great job for sure, it's a bad sucker. One day I may have me one of these buggies, right Daniel? LOL
LOL gonna take some good $$$ to convince me to let go of this one
Dammit. You stole my name that I never officially declared! And it's such a nice rig that I can't even be mad. Lol. Nice work.
Here's a little bit of tech and HP #s that may help someone else in the custom LS engine category. I learned most of this the hard way haha
I'm running a 58X crankshaft which normally comes with a 4X cam sensor. I didn't know about this until I had the buggy together and didn't put a 4X timing cover on. So, I had to use the 1X cam sensor located at the rear of the block. This means that the wiring (signal and hot) are different also. So, you have to re-pin the cam sensor connector. Not a big deal, as long as you know these things up front.
I decided mid build to upgrade engines to the one described below. This led me to swap from a standard LQ4 truck harness and computer to Holley HP. well ALL Holley EFI systems are speed density or Alpha numeric based so you no longer need a MAF. I had my intake designed for a blade style MAF so we had to do some swapping around to read only the IAT now. Not a big deal, had I known up front haha.
something else to consider when choosing your EFI is inputs/outputs. running I/O through the computer is so easy and if you are going to use a digital type dash like a lot of folks are doing then you can utilize the virtual switches. Well the HP only offers 4 I/O in the EFI harness (2+ and 2-). So, that posed a problem to me as my Speedwire systems relay panel only accepted ground triggers. So, I had to buy the additional harness for my dash and run my switches to my lights directly through it and not use the computer. This isn't a big deal, but it was more $$$. All this did allow me to have super clean/minimal wiring. I only have 1 ignition switch and 1 starter button to run the buggy. fuel pump, fans, etc. are all ran through the EFI. then I have virtual switches on the dash to control the lights. definitely the way to go in an offroad rig IMO.
now, on to the real world numbers.
408 iron block stroker (4" stroke)
Callies Crank, Molnar Rods
custom Ross pistons, 4.030" - 12.5:1 compression
custom Comp cam - GVL - .622 intake/.615 exh.... Duration @ .050 237 intake/250 exhaust , 114 LSA
Trick Flow LS2 fast as cast heads (BTR blended valve job, BTR rockers and trunion upgrade, 65 CC chambers, PM guides, BTR .055" head gaskets, .660 lift BTR platinum springs w/ titanium ret.)
summit fabbed intake with 102 mm DBC throttle boddy
Holley 66 lb injectors running 110 VP race gas
we wanted as much load as possible on the dyno so we left the driveshaft in and just pulled the flanges at the front wheels. It made 315 HP @ 6500 rpm and 264 lb-ft of torque at 6000 rpm to the rear tires on 43" MT Baja Pro-X.
so, even though this is by far the biggest HP engine I've ever had, it is no where close to 1000 hp that get's tossed around so loosely now. it seems like it is going to be more than enough for my style of driving. The guys getting more than 600 crank HP with LS's must have some seriously built engines :****:
Thanks for the real world honest info. but what were hp/tq numbers around 2500- 3500
Yours probably has north of 600 at the crank.
What kind of spindle setup are you running that you were OK spinning the front axleshafts inside the spindle at high speeds (with no slugs in place)?
(I'm assuming rockwell spindles w/ bushings? it's probably fine) :dunno:
Nick I believe if I remember correctly, he's running the Ouverson alum, super 8 hubs so I'm assuming they're Rockwell spindles to accept the 47 spline stubs.
I may be wrong
