Juan_Hong_Loe
That's dumb
Aight. I got a question for you guys. I have been working on a truck for the last week or two trying to get it to run cool.
Specs: Chevy 1 ton CUCV frame and running gear, 454 with Howell fuel injection, TH400, NP205.
It has a griffin aluminum radiator that is 28" wide 20" tall. I just made a pimp ass fan shroud pepper.gif and put a Flex-a-lite typhoon electric fan on it. We also mounted it at the back of the truck, behind the cab with about 4"-5" of room on the front side of the radiator so I know it flowing enough air. Neal and I also ran aluminum tubing all the way to the motor to help with heat disipation. The truck is still running hot!!!!!
Like 235 hot. The thing will not get over 190 sitting still but when you drive the thing it gets up to 235 and will not come back down even if you let it just idle for a while (15 mins or so). After it gets this hot you can shut the truck down and let it sit for about 30 seconds and then crank it up and the temp drops 15-20 degrees in about 5-10 seconds. Shut it back off and climbs maybe 5 degrees. It takes about another 10 seconds for the air flowing through the radiator to get cool feeling. A lot cooler than right after shutting the truck off. Here's what I'm thinking and here are my questions for you guys.
1. It has a high flow water pump on it. Could this be the problem?
2. Could the fuel injection be the problem? Letting it run too lean?
The reason for question #2 is that when he had a carb. on it it would run hot but only like 215-220. After the fuel injection it got up to the 235 range.
I don't know what else to do other than a bigger radiator. But like I said above the thing cools quick after the water sits in it for about 10-15 seconds with the truck off.
