Drcoop
DAY ONE...
So I picked up this bone stock 87 Suzuki Samurai...
Runs ok, looks a little rough, but over all not to shabby..
The only main problem is the stereo... The volume button broke off?? And you cant go without tunes..
DAY TWO...
I was determined to fix the radio... And it so happens I thought you needed to pull the dash off to get the radio out. (I later found out you didnt)
In the process of doing that I sumhow managed to crack the windshield..
DAY THREE...
After a night of dwelling about how I cracked the windshield. I decided to just replace it.. I figured the easiest way to do this would be to cut the old window out??
Unfortunatly the plasma cutter got a little away from me..
Note: Plasma cutters should have better warning labels.. Im lucky to still have all my finger...
DAY FOUR....
I was still in need of a vehicle to drive. So I was determined to piece things back together..
Lucky for me I just happened to have 5 sticks of 1 3/4" .120 wall tubing laying around. That should do the trick...
and then.....
DAY TWO...
DAY THREE...
DAY FOUR....
and then.....
