Coops samurai buggy build adventure
Its looking real good man,youre getting alot done fast im jealous.
No rear disc conversion?
Oh yes that will be done.. The axles are faaaaar from done..
I wana get a rolling driveable chassie done before I drop the mother load of cash into gears, lockers, cutting brakes, brakes, line lock, hubs, and on and on..........
Not a whole lot of progress.. But some new goodies to put on this weekend..
Got a bunch done this weekend... Got the rear end almost done.. Shocks are in, but had to redo some of the tubing.. But I think I like alot better! I was finally able to figure out how to put a "X" in behind the seats..
It was a lot tighter of a fit than I thought it was gona be.. But it all cleared... Barely!
LIKE I SAID IT WAS A TIGHT FIT...
When you put 'real' tires on, they're going to rub bad.
edit... and that creates a problem. At first I thought you could move the axle brackets inboard a few inches to clear the tire from rubbing on the shock body, but that creates a bind with the tube work on the opposite side. Wow. This looks tough. You could always run way offset wheels.
Im gona run a 2" wheel spacer.. Things should clear nicely..:awesomework:
I really started thinking about things not clearing with actual tires on...
No more worries with 38's!! and a lot of motivation...
Looks really good:awesomework:---but yeah, you sure cut it close (or at least it looks that way, when articulated that way, the opposite shock looks really close...:yikes:
Got a ton done this weekend..
OFF WITH THE FRONT END...
A LITTLE TUBE HERE AND THERE..
NEW MOTOR MOUNTS...
THE BASICS DONE...
WAS ABLE TO GET THE HOOD NARROWED AS WELL... SHES STARTING TO TAKE SHAPE!!..
THE HEIMS SHOULD BE HERE THIS WEEK.. FRONT 4 LINK.... HERE WE COME..
