Crash.... need some chevy Lt1 input
ABS fault is probably your ABS module (chaching!!!). basically you dont have ABS , just regular brakes. Have you tried resetting the system/ clear all codes?
Yeah i reset the system and it is pulling no codes now but the low trac light comes on then off and the abs nop light stays on after that.
Have you checked the fuse for the ABS system? Maybe you are lacking power to it! It is possible that the EBCM is shorted as we discussed earlier...if the fuse is blown, unplug the main power from the EBCM, then put in a new fuse & see if it blows, if not--that's likely your prob...
Fuses are good.
You changed the wheel speed sensors upfront?? If so I put money on the module.
Find someone with a lab scope, and have them check the waveforms of the remaining wheel speed sensors; just because the RF made noise, doesn't mean the others aren't bad too....:awesomework:
