doubleud
Ha! 250 hell, drop in a stock 6.0 with a cam and see how that axle handles 600 wheel hp.
You ain't even got a buggy no more. If I wanted your opinion I woukd give it to you95yj said:Now bump horsepowerup to 250 and let parts fly
that would require me getting rid of alot of nice parts you took to your housed_daffron said:Ha! 250 hell, drop in a stock 6.0 with a cam and see how that axle handles 600 wheel hp.
BUG-E J said:![]()
When this man retires I will quit wheeling. It's worth every penny to set gears up correctly.
The one and only. He has been setting up my gears and building my driveshaft for 15 yearsjdsharp81 said:That looks like Jack from drivetrain and fleetpride??
Yes they polish the gears also. When you set them up mix a little wheel bearing grease in with the pain or you will have a helluva time getting the pattern right. They are so smooth you need it to be a little thicker. I don't know the exact turn around because I always had them direct shipped to rcv. I highly recommend it though. I can't bust a set after they are treated. :****:johnnycash said:i am building the exact same axle, what was the turn around on RCV treating your gears and did they also polish them as well? Im glad to see the axle is holding up for you...
