techtafab
how deep are you guys cutting the bottom off your 14 bolts ?
I need to get on that! I could not get it scaled good enough to "trace' it so I am going to have to just follow the PDF you sent me which = more of a PITA, but I should be able to knock it out pretty fast meaning this week easily over lunch breaks.blacksheep10 said:we're doing rob's this weekend, I'm going to burn out some 3/8" plates on the table that fit what we cut. want to go 1/8"ish from ring gear without a shave job. then burn a ring that fits the new bottom plates to make a cover out of. Come on down. btw, I have my best cad whore on your header flange, I havne't forgotten you![]()
yeah, I got part of the way through the file in CAD, got sloppy, didn't pull off my base point and assumed some things, got to the last hole and I think I was off if my math was correct. I scrapped it and said **** it, let chris do itBones said:I need to get on that! I could not get it scaled good enough to "trace' it so I am going to have to just follow the PDF you sent me which = more of a PITA, but I should be able to knock it out pretty fast meaning this week easily over lunch breaks.
All the dwg files were not there anymore. Just the PDF and kelli sent me that already. I will redo it and save ittechtafab said:i sent him all the fines that i found
hopfuly he can siffer them out
blacksheep10 said:miles's started leaking like a sieve after we lipped it (didn't get into the meat, just the lip). every time he would drag a rock real well, it owuld get his cover. even after we trimmed the cover higher so it wouldn't get hit.
do you have a $ cover david?
that's what I want to get to doing after I have the plate for the bottom put in. burn a ring that actually fits that.techtafab said:hey Kelly can you burn me out a 14 bolt and a D60 flange ring so i can build a cover ?
