Dad's Mach 1
I am kinda curious why you don't just buy a ready to go stock harness?
with those kinds of things being in the harness' past I wonder if it is really gonna be safe from now on?
Literally curious. not bashing at all.
cheers
cheers
They don't repop them yet. They do for '71s, and they're like, $399.95...
My harness is on its way to Midlife harness restoration, and I have a second stock used harness on its way to me.
Pressed the power steering pulley on. Also started on the hoses. That stainless braid is a pain in the fingertips.. If it didn't look cool to me... forget it.
Tonight's progress... Got the dash harness out.
They were creative adding the tach feed. They spliced in a pink coil resistor wire... Maybe they were worried about burning it up...?
So today, I set about swapping the non tach cluster plug, for the tach instrument cluster plug, along with adding the plug and correct pigtail for the center gauges. The previous owner added the gauges by tapping into the cluster plug. I kept them tapped here so I wouldn't have to unwrap the whole harness, and re-pin the junction at the fuse block. I also cleaned up the splices.
So, unwrapped tach/gauges harness:
My hacked harness and cluster:
I traced all the printed circuits and matched them up to the wire positions in the two plugs and clusters.
How they tapped into the harness at the cluster plug for the center gauges:
How to de-pin the cluster plugs. Shove a sharp pointed awl or thin/small flat blade screwdriver in like this to disengage the retaining tab for the contact.
This guy:
Center gauge harness with the lone wire that originally went to the plug. (+ power for the gauges)
Original non gauge plug removed.
Splices done.
Bend the tabs back out, and start re-pinning the cluster plug.
These two wires were cut off and taped up near the headlight switch plug. I think they were for the alternator warning light? Was that a separate feed/socked for the cluster and plug?
Anyway, I put butt connectors on to insulate them, and use them later if needed.
Also ended up with an extra terminal from the original cluster plug. Heat shrinked it and taped it out of the way.
End result:
Well, today I painted and put in the spring cover/shock tower brace I got from California. Love those California parts. Also installed the voltage reg and starter solenoid.
Also found that the body shop did not transfer the plate and mounting nut for the horn on the LF apron, and that the holes punched in that repo for the washer bottle screws... are larger than the screws... :rolleyes:
Also found that the shock tower cap hardware is not included in the master body fastener nor under hood detailing kits... So there's another order... Hardware store carriage bolts do not fit. The heads are too thick for them to slip in.
So, I hopped back onto the under dash harness. I decided to unwrap the plug/wires for the dash map light. Glad I did...
They made it out of two different plugs.. And had an awesome splice in it to feed the glove box light...
And of course, awesome splices in the main harness to power it...
So I clipped the clock plug out of the tach, now donor harness to fix it. And ran a new wire/plug to feed the glove box light.
All wrapped up.
Ta-da. :D
Today was frustrating. No one in town had rear wheel bearings in stock. The repro muffler hangers had the holes 1/2" too far apart. Not sure if they changed in '73 or if it's a repro thing.. There definitely was a repro thing with the replacement center gauge bezel. The holes were too far apart for the cargo pocket, to narrow for the map light, and the pedestals for the gauge mounting screws were different heights..
I assembled the cluster today. I previously trimmed the side shielding from the gauges to allow more light on them to make them brighter.
Here's some differences between the tach and non tack speedo and backing plates:
And the hacking they did to my idiot lights to fit the tach in there:
So, I took my speedo, and stuck it on a tach cluster backing plate, and took my tach and put it on the proper tach backing plate. It's basically a factory tach cluster now minus the trip odometer.
I left off tonight with the dash harness set back in place. Still need to finish routing it and plugging everything back in.
Got the dash harness back in, headlight harness is through the firewall and hooked up, and dash cluster and center stack in. Also put a new printed circuit and regulator on. Working on routing the harness through the engine bay now.
Pat, I LOVE that you are taking the time to do this right...Know that your Dad would be proud...:awesomework:
So, after lunch I thinned out the engine harness. In '73, they had an electric choke, and some EGR and throttle solenoids. I only needed three... the oil pressure, temp, and electric choke.
I also deleted this harness that went through the firewall, since it wasn't plugged into anything under the dash anymore.
Finished product:
Installed:
