Dana 44, 5 on 5.5
Shopping List:
GM/FSJ knuckles (sounds like you already have)
GM/FSJ Caliper Brackets
GM/FSJ Calipers
GM/FSJ Small Bearing Spindles (these are a touch longer than a very similar Ford spindle, make sure you get the correct ones)
GM/FSJ Stub-Shafts (sounds like you have them)
Ford F150/Bronco Hubs and Rotors, TTB stuff works as well.
What ever 19-spline locking hubs you want to use.
Bolt and go.
You can piece it together from the junk yard/pull-a-part pretty cheap, and the hub/rotors are pretty cheap new from the parts house. Sounds like Pookys got the quick hook up for a good 1/2 of it, all you would need are calipers and stands.
Yep, hes on his way here to get what I have. all he will need is the caliper mts, calipers and locking hubs if he wants them.
Thanks again Jim. I think the only things I need now are calipers. I'm pretty sure the brackets I have are off a Chevy. If not I'll find them soon enough.
should have just bought my whole from end.
detriot, disc brakes 5 on 5.5 high steer... oh well guess it will be at the swap meet in Puyallup...
your right.
it is narrow width but passengers side drop.
i know. he could just turn it over and make it a high pinion!!! LOL
ok I'll give you a call. I only have today off for the next week or so. So tonigth would be perfect or later today. I'll go get my haircut to pass the time. :awesomework:
What hair??? :fawkdancesmiley:
