I took apart my 60 and removed the knuckles...
Well, I started cleaning up the parts to inspect and see if I needed to replace anything and the upper bushing didn't look right...
The hole on the top is offset and has 1 deg stamped into it... It's also grey not white...
After a bit of searching it appears that someone has replaced the original kingpin bushings with an adjustable camber one...
Anyone ever see this???
I found a website with a pdf that shows the kit I have... It's at the very bottom of the page...
Tell me what you think...
http://www.specprod.com/CATALOG_DIR/LtTruckSUV_08.pdf
