Binder
this is as dumbed down as I can make it
One wheel turns faster than the other when motion is stopped? You're right that is dumb.:haha:
Its when a diff builds backlash, that the locker locks, correct?
With too much throttle they won't unlock.
Yup! And notice that no place in there does it say under load or under throttle.:;
Bullshit! It's dependant on traction not throttle.
do I need to explain why the tires spin different speeds on a corner?
unless under load then it spins the same as the inside tire
People also seem to think that Detroits actually POWER a tire faster than the other side. While there are times this appears to be the case, it is incorrect.
There are times when climbing a tough hill, usually high speed, that a front tire gets airborne and spins faster than the diff. This is due to axle shaft wind up. The shaft is winding up like a torsion spring and when the tire leaves the ground the spring action causes the the tire to overspeed and unlocks that side. The tire is spinning but it is not receiving torque from the diff.
You don't need to explain anything to me but if you explain it wrong I will call you on it.
If you still believe this then you're still wrong. Believe what you want but if you spread bad information you will likely get called on it.:cheer:
if they didnt stay locked under hard throttle then when I am doing dognuts with my junk with a detroit in it I would only leave one rubber patch......
Because you lost traction. It's about traction and the resulting wheel speed. Why would you leave a single tire patch when the diff is locked by default.......People seem to be thinking about this backwards. The Detroit doesn't lockwhen conditions are met it's locked all of the time until the conditions are met then it unlocks.
you my freind are the one who does not get it...are you going to have a tantrum now? :kissmyass:
your being a tool Binder....calling you out on it now
:stirpot:
