Re: Re: Dodge owners
Sent from my XT1635-01 using Tapatalk
Not sure that's the case. In my simple mind once the clamp let's go the line is able to vibrate with the engine. On my truck that's what happened. I've checked the bolts at every oil change. When the line that failed got pulled off I put a wrench and pliers to see it the bolt worked loose. The bolt was still tight but the part of plastic where the line goes through was loose. Maybe unbolting them works but I don't see how.The-Boss said:Well I looked at mine today and was surprised to see the clamps for (if I remember right) 3, 4 and 5 were not even bolted down. Just laying there where I could spin them around the line by hand. I assume this was deliberate from the previous owner. Is unbolting the clamps a common thing to eliminate the problem?
