Or a ss chassis...that would be blingin
That would be
Perfect for the NW
nobody huh? So you're saying they're all moly?
A lot of the Alston Chassisworks kits are available in HREW and DOM, as well as chromo.
The roll cage benefit of DOM or 4130 is not about the alloy. The benefit is in how both tubes are rolled at the mill. In either case the tubes are are extruded to a greater degree and at higher temperature. This produces a very fine grained piece of tubing. The fine grain makes the tube extreemly tough and crack resistant. It is more dificult to kink and collapse these tubes than a hot rolled electric welded tube.
If you ever get the chance, throw a similar sized piece of either in the press, the vise and work it over with a hammer. You'll become a believer.
Regarding the concern over post weld annealing 4130. Some years ago I sent away to the American Welding Society for a pamphlet they published on welding this alloy. What the AWS said is that the alloy will cool to the normalized condition and no weldment annealing is required unless: the material is 2" thick or greater or the material is below freezing temperature when its welded.
HREW or moly as chop shop stated.
Not as common, but still used. There's a dom cage in my luv and my old man's 'camino. No need for chromo and not a fan of hrew
SFI only sees DOM as mild/HREW. To them they are one in the same.
They only see moly and HREW when certing a chassis.
yeah and? Still no need for chromo and still not a fan of hrew. That leaves me with dom
i think its already been said a few times.....money.:awesomework:I guess my point is if the SFI doesn't recognize DOM and they do moly why don't more off road guys use moly when you can get a lighter product that has the same strength....???
JESUS FAWKING CHRIST YOU DRAGRACER. Your on a wheeling site.
OK..im calm now...Ive only heard of a handfull of chromo chassis being built for rock rigs. We beat the crap out of em and replace tube so dom is much easier all the way around to repair.
Are you asking the question because yer building a rock rig or cause you want to:stirpot:
Actually I was asking because alot of the welds I see on stuff being built look less than beautiful and I don't see many TIG welds.
That being said I was curious why very few use moly but now I gather it is cost and that it has to be tig welded.
I am starting to overhaul my CJ and was thinking of moly as the stuff is lighter than mild or DOM and it just seems like a higher quality finished product when you use moly.
Lighter and stronger is always good.
You can lead a dog to water.....
I guess my point is if the SFI doesn't recognize DOM and they do moly ....???
Most excellent. If you treat it then yer twice as strong as dom, But heat makes stuff move and doing a chassis would be insanely expensive.
I got to wondering a few years ago, Dustin Webster had a new chassis tigged up from chromo but he didnt treat it...was it too expensive to have it treated, or what...got me to thinking why.
Here's a few pictures of a Dodge pickup that tumbled at 70, it's trailer and a shitty DOM buggy that started out tied to the trailer....7 roll's later.....other than the broken wheel it was fine to drive away from the accident site.
And everyone elses point is nobody cares what SFI thinks.
I still don't believe cromo is stronger without proper heat treating unless someone can provide documentation showing so.......:corn:
Stronger or not it's not necessary, that's a fact!
