Doors on buggies - pics please
Use the latch pins like what is used on a weight bench to adjust them. I think polyperformance sells them, I know they use them on their adjustable column. I use heims for the hinge and make the doors bottom out into a piece of .250" wall tube that is cut into a half moon. I usually build 2-3 catches, and 2 latches to hold the door shut in a hard roll or impact
**edit** here is the pins http://www.fitness-equipment.com/acatalog/Fitness_Equipment_Pull_Pins____Pop_Pins_264.html
Kingsnakes buggy had some basic doors that you could throw a panel over. Everything Woodlee puts together has been tested in some way shape or form!
