OverkillKustoms
Member
- Joined
- Sep 4, 2015
- Messages
- 7
*****TIRES IN PICS HAVE BEEN SOLD********
I have a set of 4 Humvee Double beadlocks that have been recentered for the Rockwell 2.5 ton axle and have added a Bluetorch Fab rockring to protect the eight clamp bolts. I have new O-rings for the wheels and they also feature welded in nipples for a schraeder valve (included) on the inside of the rim to protect them. The rims are powder coated green, inside and out. Built these for a crawler I was unable to finish. Never been used. They are complete, except the lack of inserts. TrailWorthy Fab sells pvc inserts that will work with these. I am located in Delaware, Ohio and I am asking $700.00 US dollars for the set. I will also consider trades, looking for 14 inch coil-overs, Detroit True-Trac limited slip for a GM 10 bolt front (8.5 inch ring gear) and also a True-Trac for the 14 bolt rear. Or a decent four stroke dirtbike or quad.... I can be texted or called at (740)272.1582 if I don't answer right away, leave a message, I actually do check and return missed calls unlike some of today's fellow humankind. I'm not on here very often, easier to reach me through text message or calling.
