tripsixtoy
Active Member
ok so i have an 80 toyota pickup with a about a 4-5 inch lift. the problem i am having is my drive shaft is at such an angle now that the yoke is rubbing on the pinion flange and causing me to blow u-joints. my question is what is the best way to fix this, i have been told two ways and that is to 1: cut the spring pearch's and rotate them or 2: get wedges and put them between the springs and axle.
by the way it is my front drive shaft that im having the problem
