unclestripey
Can anyone tell me what the difference in length is between an 83 toy front shaft and an 84-85 front shaft? Thanks!
should be two lenghts of 1st gen shafts.
I thought it was 5.5" longer....better let graysquirrel measure them.
Maybe it is lol i just was going off of memory
What I'm doing is using them for shafts on my sami. The 84-85 front shaft is supposed to be a real good fit and is supposed to alleviate the vibrations associated with the compound angle one gets when putting a toy rearend in a sami. So far I've only been able to find a shaft from an 83.
What do they want for the 83 shaft???
It's already in my hot little hands.
Ok..cool!It's already in my hot little hands.
Oh yeah! Fergot about that!!! Thanks Trashy! And Unc, don't give up that 1st gen shaft just yet...:;I wouldn't get too wrapped up in trying to locate a 84 or 85 shaft only.. Any shaft after 84 will have a MUCH better maximum operating angle than a first gen and the later CV can be modified pretty easily to have the same angle as the 84-85...
http://www.4x4wire.com/toyota/tech/cvmod/
There ya go Unc...:awesomework:I got an 84 85 shaft if ya need one. PM me.:awesomework:
You can use a first gen CV with the bolt holes drilled to 10mm for strength and a later model slip on the other end for a no major mod needed high angle setup. :;
