dual cases vs 4.7 gear
i agree, the extra length in the front would be nice. but, ive never had an issue with the front shaft being TOO short. just too little travel...:mad:
think of it this way, a longer shaft with the same amount of lift is going to be a less angle and more paralel to the springs and wont need as much slip yoke travel.:awesomework:
Exactly why I'm waiting to have a d-line made until after i get duals:awesomework:
how much length do u gain with a dual case? 6"?
thats be like what a 1/4" maybe even a 1/2" less travel?
my frontend is(was) forward almost 3" already, i still pulled the front shaft apart..more times than i care to admit:mad:
i moved it back when i did the crossover, since the draglink, was hitting the tierod. its still forward about 1.5"
not, that i wouldnt take that extra 1/2" or so of travel. might keep me from crawling under the truck in the snow, to put the DL back in:rolleyes:
Oh and a after thought on the single 4.7 subject. Last year (only had the 4.7) got into a situation in the snow on the back side of Evans were I needed to keep the wheel speed up to get out of a bad spot. Had to keep it moving so in 3rd with the 22re screaming for 1/4 mile. Developed a rod knock afterwards, limped it till this summer and put new engine in. If I'd of had more gear options I wouldn't've had to stay so high in the RPM's. Or if I'd of known the area better I could've kept going in the direction that I thought I shouldn't have and not had to wond out RPMs to get up the other direction. Hope this makes sense, cuzz it was crystal clear in my head.
I got dual cases with 2.28 in each with the twin stick and love them...until I have to wheel behind Muddpigg when he drops his stuff into compound low with those 4.7's and my brakes start to smoke :redneck:
:haha: :haha: I'm jonesen to hit the mountain. It's been too long, retarded work.:mad: :mad: :mad:
I've been running a single 4.7 case for a while now with 4.88 diff gears and maybe wouldve went duels without the added cost of converting from v6 chain to 4cyl gear drive. I love my setup and can generate plenty of wheelspeed with the trans. gears. the only draw back so far is generating wheel speed in reverse, but who needs reverse anyway.
