Electric Fan Placement Push or Pull?
So what about this? If I run a 16in pusher on the front, will running a 12in puller on the back help or hinder the effects of the 16 inch?
Well after receiving my fan Im going to have to go pusher, no room to set up as puller. Way to close to the motor, you really would have to have alot of room for a puller, Seems to push the air through quite well.
It would help... but do you have room for a 16" puller?
Nope, don't really have room for a 12" puller either, but I should be able to make it work.. Do you know if there's a shorter nosed waterpump that will fit on the 2.3 lima? I've got about 1.5 inches between the radiator and the front of the pulley, which has the double v on the outside of it. I'm only using the serpentine, but the flange on the waterpump goes all the way to the outer pulleys.
