Bones
That Guy
We have a problem here Houston
Installing brackets on the new bike for the hard bags.
go to install said bracket on the left side
Per instructions use 2-8mmx30mm allen bolts, if your VIN ends in 235345 use this 5mm spacer, mine did not so no spacer is needed, run the bolts in...well damn! the spacer is needed. Go to back the bolts out and they do not budge, snapped both off about 3/8" left hanging out of the subframe. Not a chance vice grips will get it out.
I am afraid that if I cut them off flush and try drilling them out to attempt an EZ out (doubtful), or just one size larger and retapping the holes and using a size larger bolts than before. Easier said than done getting everything center punched dead nuts. Last option and my personal favorite is finding a guy that can TIG this bracket to the bolts with the spacers and all that.
Am I on crack to think this is a proper fix? I can get pics if needed of my F-up
