Fire Extinguishers
Also... 2.5lbers aren't enough for a real fire. You're just wasting your time! Get a bigger extinguisher!!
Halon is a cfc and they stopped making it in 1994, all of the halon that is available today is recycled or from what was left over. My vote would go with cold fire. I am a firefighter and we use foam on vehicle fires when there is a heavy fuel load. I also work for nascar track safety and at the track we also use foam in all of our water cans along with in our tank water. Foam works, that's why we use it.
John,
For comparison, what size is the one you pictured? Also, since Coldfire uses volume measurements, what size conventional extinguisher (weight based, 1lb, 2lb, 5lb, etc) would you say it most compares to physical size wise. I'm trying to get a mental image of how big these are to gauge what I can best fit in my rig and where.
For comparison one site I was on listed the following sizes:
2.5 lb: 15 1/2" x 3"
5 lb: 15 1/4" by 4 1/4"
Thanks,
JohnG said:
What I have on buggy, except mine is winterized version, I think it was a little extra.
$105.00
Found this description.
2 Liter Cold Fire Extinguisher withindustrial double bungee mounting bracket. This unit is very close to the size of a 5lb ABC fire extinguisher.
So the 2L ~ 5lb
1L ~ 2.5lb
Re: Re: Re: Re: Re: Fire Extinguishers
SomewhiteGuy said:
Don't know if can be used with field service ends but thats what I am running.
linky http://www.discounthydraulichose.com/Blue_Push_Lock_Hose_p/3385-hose.htm
Not fuel rated and other stuff I seen like this is not recommended for fuel.
I just bought fuel and trans fluid lines from summit, same stuff WOD sells. Black Nylon outer webbing and SS wire inside hose. AN fittings.
The Mil grade coldfire mix is good to -50º. Any idea what the regular stuff is rated for?
I probably won't ever be out wheeling in freezing or below weather anyhow, just curious really. I currently have 2 2.5lb ABC extinguishers in my Jeep but I'm not at all opposed to something better that will put a fire out faster.
The standard will freeze at 32, just like water. Our application requires the cold weather formula.
Diamond B said:
John,
Thanks,
Mine are the size of a 5 pound extingusher.
Hey guys, don't mean to blow up your forum but anything you need for fire suppression capabilities we can design it or kit it together for you. We develop means of deploying Cold Fire agent to the fire through extinguisher use and fire system on-board systems that are all self refillable.
We are in Pelham, Alabama and serve the following communities: Racing for INDY and Formula One - Logging & Forestry - Military SOF - Law Enforcement & SWAT - Fire / EMS
We also carry rescue tools and gear for hauling people out of the woods as well as individual first aid kits that'll fit in your pocket or SHTF bag.
http://www.coldfiresoutheast.com Informational Site
http://shop.coldfiresoutheast.com/Racing-Off-Road_c5.htm Online Store
800-741-0021 or email at info@coldfiresoutheast.com
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcQyGP0r6W-ZTnDYqL_PgK-BT-rw45FXn9XGJfyLgOpmWRBB2oWP
Welcome to Hardline. We are happy you have decided to join us. I have your stuff on both of my buggies. To jog your memory, you delivered it to my store in Pelham, ABSCO Fireplace & Patio.
Feel free to advertise your wares in the vendor section. We always like to do business with vendor that post here. It also helps when some vendors decide to give Hardline discounts or specials. :fish: I want to bring the SOLO Buggy by and have you give me some suggestions, more than the one extinguisher that I now have.
Sounds good. I can create "Hardline" word as a group coupon code for discounts for y'all.
Bring over the buggy. Only if you drive me around! Ha! Look forward to working with your group.
Cool. Solo Buggy is a single seater, and you are not sitting in my lap, I'm not that kind of guy :flipoff1:
