C
Cole
Guest
rock mafia said:. The switches arn't real reliable, and the wiring is a PITA to work on.
I don't think I will have to worry about the wiring part. I will leave that up to someone else.
Travis said:Same thing I have in mine, I personally like it better than an Art Carr.
Yeah, you only pull the handle up to get reverse and park. I can shift between any gear and neutral without touching the handle. It is gated, but isn't staggered like an AC. It is a cable shifter and doesn't lock.P said:Do you only pull the T handle part to get by the Reverse and nuetral lockout ? Is it a ratchet style shfter or does it lock out each gear change ?
