Motor wires mixed up?
~T.J.
On the bottom of the radio you have a switch for channel 1/2/3 I believe you can switch channel 2 and switch the direction of what the radio sends out.
Also what ESC? I have seen a few do this and you can disc the battery and re-connect it and the motor will go the correct direction...
Goat brushless system
I swicthed the channel switch and it worked but the steering was reversed...
would it do this if the recivers was going south or a low batt?
Did you program the ESC? There is an option for reversing the motor :awesomework:
Uh, with brushless I thought all you had to do was switch 2 of the 3 wires to reverse the direction... or has that changed since I built my whirleybird? :eeek:
Innrunners/outrunners The goat sys is an innrunner...
jack that was happining to me and still is all i did was had crash elp me figure what channel it wass and switched it. if you changed a channel and it switched your steering switch a different channel and see
Are you running a tq3? I am half temped to grab a different radio, I will pick it up again tonight, damn I was pissed off last night.:haha:
