Mitchell Ex
Active Member
- Joined
- Nov 1, 2014
- Messages
- 29
- Reaction score
- 0
http://www.wideopendesign.com/Product/11196/Drive-Shaft-Carrier-Bearing.aspx This should do the trick
I don't have the room for a 2 PC.Mitchell Ex said:http://www.wideopendesign.com/Product/11196/Drive-Shaft-Carrier-Bearing.aspx This should do the trick
i ran the pto sutff before and the splines twisted when i linked it i used factory sliptommy450r said:An here it is all together
Hmmm.. u call it redneck, I call it dam near genius.. Some of yall really make me feel dumb sometimes. Dam modern day McGivers!tommy450r said:This is redneck but I took a pto shaft extension an cut the female splines off about 1/2 inch from the male splines an turned it down to a press fit in the dom then I took a 1350 slip yoke cut the tube off of it an opened the center up as much as I could to make it press fit on the male splines.
That may not make since but I got pics if anybody needs em. I ended up with about 12 inches of splines for the slip joint an the splines are almost 1 3/4" so it should hold up.
RebelRider said:So, I've decided to order a toyota output flange for the atlas. I'm going to try and run a toyota cardine joint up top since it's such a steep angle. I will also for sure be limiting my droop.
Any suggestions on where to buy the flange besides high angle driveline? Must be 32 spline.
I wouldn't do that.RebelRider said:So, I've decided to order a toyota output flange for the atlas. I'm going to try and run a toyota cardine joint up top since it's such a steep angle. I will also for sure be limiting my droop.
Yea, I was just informed this wouldn't be a good idea. I'm going to try and run a single joint 1350 on both ends. I'll possibly need to move to 1410.Neal3000 said:I made that mistake when i first put my atlas in, spent my money on toy flanges so i could keep my toy d-shafts front and rear and they quickly became the weak link, first the rear, then the front.
RebelRider said:Yea, I was just informed this wouldn't be a good idea. I'm going to try and run a single joint 1350 on both ends. I'll possibly need to move to 1410.
