Ftoy #518 build
Re: Re: Ftoy #518 build
Good thing iv got a peg leg
Thanks sorry for chitty pics. Camera lens on ph broke a while back and since I picked the lens out this is the quality I now get.
All this lil chit adds up
Adds up in a hurry, this is the Shiat that will nickel and dime you to death
Sent from my iPad using Tapatalk
Re: Re: Re:
hjpcummins said:
Thanks! It's coming along... only think let to buy is brake lines. Feels good saying that
Just finished running all the hardline from master to link bars and axel T to calipers.
Iv seen hardline ran down links with hose at both ends tieing back to hardline, and iv also seen hose ran down the entire link .
Any obvious reason I shouldn't run a solid hose down the link??
Besides stopping off by the local hydro hose shop. we're are you guys ordering these long hoses
The ones I have dome the brakes on for several guys i always have run the solid down the link arms and flex on the ends I always use the kits from WOD they have everything you need to do it with the exception of the hard line they have different fittings depending on what master cylinder you are using you will need a 37 degree AN flaring tool for their fittings I have a diagram I can Email you that will help you understand what you need if you want it let me know
Summit only has -3an Hoses over 20"
Unless I'm missing somthing?
The WOD kits have way more then I need at this point.
Kevin, since I'm new to links I really font wana run solid yet due to me possiably changing it soon ( inproper geometry)
I understand ! I Emailed the diagram anyway just so you will have it for future use
Got a quote from a local shop on 1-30" line and 1-40" non SS
$85
seems expensive.or am I just that much of a cheap ass.
Wish they made rebuildable ends like my fuel system...
Ended up just going the local route with the brake lines. But im ordering spare parts online.
Ther are a few things iv overlooked On the th350
the tv cable is non existant. What are most doing about plugging it (rtv?) I'd rather plug it, but Google 85 coming up empty with a cheap fix besides rtv.
Are most also blocking off the vacume port?
Re: Re: Re: Ftoy #518 build
85toyo said:
I believe the vacuum modulator is required if you're still using a auto valve body.
Iv read about this, but haven't found a defiant answer.
if you dont use the modulator you need to get some light weight springs to put in the govenor
Just tinkering around since I have had a chance to pull the Trans to see why it won't move any any gear ?!?!?
started on engine cage
also in the middle of getting my unit bearing bored out to accept 35 spline shafts..
