Ftoy #518 build
I hope not! She just turned 1 Monday. Growing up way! To fast
Got bored last night and didn't feel like messing with the drive train. Threw this togeather!
Cooler storage.
It will be hinged on tabs
**** ' around this evening started the big and powerful 22r just to see if my dreams come true and it's locked up( so a. V8 gets installed sooner then later!)
Sent from my iPhone using Tapatalk - now Free
You seen the mod that uses the factory PS reservoir cut in half and a piece of big (4" I think) exhaust tubing welded in to increase capacity? Doesn't get any cheaper than that. Lovin the build so far.
Thanks !!!
Yeah I've seen it! I came across a plastic one double in size. Just trying to keep things looking clean.
QUEStioN
I'm building shock towers tonight
My question is. How much up trave compared to down travel is best for best articulation
The shocks I've got my eyes on are 36" extended and 21" collapsed
I cycled my suspension and measured and measured and measured, droop to stuff and left an inch or two of shaft showing or in the shock body then built mounts. Pretty sure there is an easier way but thats how I did mine.
Small shock hoop location issue.
Got the dash cover cut out
Small safety issue I see with this being open for the I joint to fall apart or somethne hand to fall in.
Best bang for the buck shock I could find
And 15" travel
http://m.summitracing.com/parts/ran-rs5036
What's y'all thoughts?
