moose99ps
Active Member
anyone made a fuel cell from a keg?? thats my plans.. ive been looking online for parts but cant seem to find a whole lot for bungs to weld into the bottom for a sump...
Did you ever figure out the block off plate question?plan is to run a fuel supply line off the bottom of the tank. trying to find a filler neck and cap that seals because i might roll it and dont want fuel spilling out of a vented cap. so i should only need one line off the bottom and a roll over vent line from the top correct? carbeurated cj with no return. swapping to a holley blue pump with reg. will a 350 block off plate work on a 258?
I'm converting my 258 over to a electric fuel pump and I'm trying to find a block off plate.
