FULL HYDRO ISSUE
DAMN SMART PHONE...
DO ALL YOU RUN COOLER SEPERATE FROM RADIATOR WITH AN ELECTRIC FAN?
I GUESS I HAVE NEVER PAYED CLOSE ENOUGH ATTENTION TO THIS ASPECT OF OTHER PEOPLES RIGS.
Re: FULL HYDRO ISSUE CYLINDER PICS ADDED
GUYS, THANKS FOR ALL THE HELP. IN THE PROCESS OF HOPEFULLY WRAPPING THIS THING UP. THAT BEING SAID, CAN SOMEONE SEND A PICTURE OF THEIR SINGLE ENDED FULL HYDRO MOUNT? I HAVE PASSENGER DROP 60 AND THE U-SHAPED END WHERE THE PIN GOES THROUGH RUBS THE TOP OF THE DIFF EVER SO SLIGHTLY. I KNOW RUNNING A PSC RAM WITH HEIMS ON EACH END WOULD CURE THIS, BUT TRYING NOT TO SPEND MONEY IF THERE IS A FIX. I HAVE HIGH STEER ARMS AND IT APPEARS SOMEONE TRIED TO ADDRESS THIS BY ADDING 5\8 To 3\4 WELD IN "RISERS". ID LIKE TO REMOVE THOSE SO I CAN RUN 3/4 BOLTS AGAIN BUT FROM WHAT I CAN TELL, THAT WOULD MAKE IT RUB EVEN WORSE.
THANKS IN ADVANCE.
I ran RP full synthetic and it made my stock GM pump whine like a Lil bitch. Put normal ps fluid in it and it's been good since.
Re: FULL HYDRO ISSUE with new pics added
HERE ARE SOME PICS FROM WHAT I WAS TRYING TO DESCRIBE IN MY ABOVE POST
Anyone??
