Gears for my toyota
I am running 5:29's with 33x13.50.22r and could not be happier speedo is on good crawl for trails and perfect on highway
you can get the trail gear creeper gears for 139. there built by yukon. if your interested in those ill give u the shops name that i got mine threw. free shipping. but if megatoy has em for 150 id give him the money
I can do the trail creeper gears for $130.00 each. :beer:
there ya go....good deal ! let me know when u get some install kits in. i need 2 masters. how much do u usualy sell em for ? think the tg ones are 99 ? and can u get other tg products ?
I can get it all..... Master kits are $95.00.
Anyone runnin' 5.29's on the street DAILY? Will they run hot if driven, oh say, 8 hrs straight?
Was gonna do 4.88's, but thinkin' 5.29's may be better.....and I drive my rigs everywhere....no trailers.
i have put thousands of DD steet miles on my genuin:puke: 5.29's and there still holding up fine,
i can set up and install yer gears for a small fee:awesomework:
If you running 36 inch or bigger tires..no problem.
FWIW i beat the crap out of genuine gears that i set-up for 4 years. No breakage, well until the inner birf seal let loose and all my gear oil went away.
yep, ive been running mine for YEARS. 1,000's of miles also. with 35's, on my DD.
I dont think 1000 bucks is going to get you where you wanna be lift tires gears steering etc. Once you start these things its like a can of worms. Alot of things can be done for cheap but it takes some skills and sounds like you dont have much experience yet.
Gears will cost 800 if you pull your own thirds and pay someone $150 each for install. In my opinion not really worth doing if your not installing lockers at the same time.
If your just cutting your teeth, new to working on rigs and on a limited budget, here is what I'd do. Should be able to do it for around $1000
Buy a new 4" lift kit. The parts will go on easy and have instructions.
Buy a good set of used 33" tires on 8" wide wheels.
Buy a lightly used warn 8000 winch with a mount or bumper that bolts on to your rig.
You should be able to do all this yourself with limited tools. It will also allow you to run most of the trails and develop you offroad driving skills. Also 33's and open diffs will minimize broken parts.
